- To: Thery Laurent <thery AT ns.di.univaq.it>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] A little question about modules
- Date: Wed, 4 Feb 2004 12:20:41 +0100
On Wed, Feb 04, 2004 at 10:52:33AM +0100, Thery Laurent wrote:
> Hi,
> I'm trying to use the module system to see how I could simplify some of my
> developments.
> The typical case I encounter is a hierarchy of files that share common
> parameters (or at least a common subset).
> Here is a toy example.
> I thought I could use functor to get rid of these locals.
> So my first attempt was to functorize everything, starting
> with a type for my parameters:
> Module Type PARAM.
> Parameter param: int
> End PARAM.
> File A:
> Module FA (X: PARAM).
> Export A.
What do you export here? The whole module-file A? It is impossible since its
existence starts when you finish the file. Or you mean Export X?
> Theorem A1: ... param ...
> End FA.
> File B:
> Require A.
> Module FB (X: PARAM).
> Module F1 := (FA X).
> Export F1.
> Theorem B1: ... param ...
> End FB.
> File C:
> Require A.
> Module FC (X: PARAM).
> Export F1.
> Theorem C1: ... param ...
> End FC.
> File D:
> Require B C.
> Module F1 := (FB X).
> Export F1.
> Module F2 := (FC X).
> Export F2.
> Theorem D1: ... param ...
> End FC.
> But this does not work because F1 and F2 contains two different
> versions of A.
No! They do not "contain" A at all! Well, not more then B or C. If there is
something wrong, it is probably a bug.
> So my current solution is to linearize my hierarchy:
> File A:
> Export A.
> End FA.
> File B:
> Require A.
> Export F1.
> End FB.
> File C:
> Require B.
> Export F1.
> End FC.
> File D:
> Require C.
> Module F1 := (FC X).
> Export F1.
> End FC.
> This works quite nicely, there are only two small problems:
> first there is this module F1 that is hanging around. The more files
> I add the deeper A1 (F1.F1.F1.....A1) is. What I would like in fact
> is to avoid creating the module and just write Export (FC X).
This would require serious modifications of Coq... introduction of global
names of the form (FC X).A1, completely different approach to implicits,
morphisms, hints etc allowing for module-level patterns, like (FC ?).A1.hint
for example...
> second I've lost my hierarchical structure.
> Is there a better way to use module to do what I want?
Your first approach is definitely better :)
Jacek
> Laurent Thery
> Bug reports: http://coq.inria.fr/bin/coq-bugs
> Archives: http://pauillac.inria.fr/pipermail/coq-club
> http://pauillac.inria.fr/bin/wilma/coq-club
> Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] A little question about modules, Thery Laurent
- [Coq-Club] Announce: Cyp tool, Thery Laurent
- Re: [Coq-Club] A little question about modules, Jacek Chrzaszcz
- Re: [Coq-Club] A little question about modules, Thery Laurent
