coq-club - [Coq-Club] inductive definitions
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] inductive definitions
  • Date: Fri, 20 Feb 2004 12:12:58 +0100 (CET)
hello! could anyone explain me why, in the following code, the first
definition is accepted, while the second one is not? is it normal or is it a
bug? thanks.
Require Export Bvector.
  Definition var := nat.
  Definition symb := nat.
  Variable arity : symb -> nat.
  Inductive term : Set :=
    | Var : var -> term
    | Fun : forall f : symb, vector term (arity f) -> term.
  Variable A : Set.
  Variable xint : var -> A.
  Variable fint : forall f : symb, vector A (arity f) -> A.
  Fixpoint term_int (t : term) : A :=
    match t with
      | Var x => xint x
      | Fun f v =>
        let fix termvec_int (n : nat) (v : vector term n) { struct v }
            : (vector A n) :=
          match v in (vector _ n) return (vector A n) with
            | Vnil => Vnil A
            | Vcons t' n' v' => Vcons A (term_int t') n' (termvec_int n' v')
          end
        in fint f (termvec_int (arity f) v)
    end.
  Fixpoint term_int2 (t : term) : A :=
    match t with
      | Var x => xint x
      | Fun f v => fint f (termvec_int2 (arity f) v)
    end
  with termvec_int2 (n : nat) (v : vector term n) { struct v }
       : (vector A n) :=
      | Vnil => Vnil A
      | Vcons t' n' v' => Vcons A (term_int2 t') n' (termvec_int2 n' v')
    end.
Error:
Recursive definition of termvec_int2 is ill-formed.
In environment
n : nat
v : vector term n
t' : term
n' : nat
v' : vector term n'
Recursive call to term_int2 has principal argument equal to t'
instead of v'
