coq-club - Re: [Coq-Club] infinite trees
chronological Thread
  • From: Venanzio Capretta <Venanzio.Capretta AT mathstat.uottawa.ca>
  • To: Milad Niqui <milad AT cs.kun.nl>
  • Cc: Solange Coupet-Grimal <Solange.Coupet AT cmi.univ-mrs.fr>, coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] infinite trees
  • Date: Mon, 01 Mar 2004 10:25:37 -0500
Thank Solange and Milad for your suggestions.
As I mentioned in the original question, I am using an alternative representation based on vectors as functions from finite sets:
Parameter Finite: nat->Set.
Parameter nat_index: (n,m:nat)(lt m n) -> (Finite n).
Parameter index_nat: (n:nat)(Finite n) -> nat.
Hypothesis index_lt:
(n:nat; i:(Finite n))(lt (index_nat n i) n).
Hypothesis inverse_nat:
(n,m:nat; p:(lt m n))(index_nat n (nat_index n m p))=m.
Hypothesis inverse_index:
(n:nat; i:(Finite n))(nat_index n (index_nat n i) (index_lt n i))=i.
Definition Vector[X:Set]: nat -> Set:=
[n](Finite n)->X.
(* There are a couple of obvious implementations of Finite, definied by
  Fixpoint or by Inductive.
Variable label : Set.
Variable child: (a:label)(Vector label (size a)).
(* It is also easy to define "child" from "children", that uses lists. *)
CoInductive Tree: Set :=
Node: label->(n:nat)(Vector Tree n)->Tree.
CoFixpoint makeTree: label -> Tree:=
[a](Node a (size a) [i](makeTree (child a i))).
My question was specifically about the type Tree defined using lists.
I think this example is an argument in favor of the "coinductive types as final coalgebras" definition against the "guarded by constructors" conception.
It seems to me that implementing the coinductive principle stating that there is a unique morphism from any coalgebra to the inductive type would be much easier than extendin the definition of "guarded by constructors".
Maybe this could be a suggestion for future versions of Coq.
-- Venanzio
