- To: S�bastien Hinderer <Sebastien.Hinderer AT loria.fr>
- Cc: Coq <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Vectors
- Date: Mon, 05 Apr 2004 11:19:16 +0200
Hi Sebastien,
May I add my solution after Yve's and Pierre's ones.
First, you build the identity function upon vectors :
Definition Vid : forall n:nat, vector n -> vector n.
Proof.
destruct n; intros.
exact Vnil.
exact (Vcons (Vhead H) (Vtail H)).
Defined.
Then you prove that this function is exactly the identity :
Lemma Viq_eq : forall (n:nat) (v:vector n), v=(Vid n v).
Proof.
destruct v; auto.
Qed.
End, you use it for proving your theorem :
Theorem VSn_eq :
forall (n : nat) (v : vector (S n)),
v = Vcons (Vhead v) (Vtail v).
Proof.
intros.
change (Vcons (Vhead v) (Vtail v)) with (Vid (S n) v).
apply Vid_eq.
Qed.
Yours,
Jean.
Sébastien Hinderer wrote:
Dear all,
Assume the followng definitions, inspired by the Bvector module of Coq's
standard library :
Section VECTORS.
Variable A : Set.
Inductive vector : nat -> Set :=
| Vnil : vector 0
| Vcons : forall (a:A) (n:nat), vector n -> vector (S n).
Implicit Arguments Vcons [n].
Definition Vhead : forall n:nat, vector (S n) -> A.
Proof.
intros n v; inversion v as [|a p w]; exact a.
Defined.
Implicit Arguments Vhead [n].
Definition Vtail : forall n:nat, vector (S n) -> vector n.
Proof.
intros n v; inversion v as [| a p w]; exact w.
Defined.
Implicit Arguments Vtail [n].
(How) Is it sossible to prove the following theorem in Coq ?
Theorem VSn_eq :
Thanks in advance for your help,
Sébastien.
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] Vectors, Sébastien Hinderer
- Re: [Coq-Club] Vectors, Pierre Letouzey
- Re: [Coq-Club] Vectors, Jean.Duprat
- <Possible follow-ups>
- [Coq-Club] Vectors, Yves Bertot
