- From: Roland Zumkeller <Roland.Zumkeller AT polytechnique.fr>
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Inductives in Modules
- Date: Thu, 13 May 2004 16:27:09 +0200
I'd like to use modules to do model first-order signatures and algebras on them :
Module Type Signature.
Variable V : Set.
Variable F : nat -> Set.
End Signature.
When defining the following module
Module S : Signature.
Inductive V : Set:= X | Y.
Inductive F : nat -> Set:= Plus : F 2 | Zero : F 0 | One : F 0.
End S.
I get this error message:
"User error: Signature components for label V do not match"
However when defining the inductive with another name first, everything works fine.
Module S1 : Signature.
Inductive V_ : Set:= X | Y.
Definition V := V_.
Inductive F_ : nat -> Set:= Plus : F_ 2 | Zero : F_ 0 | One : F_ 0.
Definition F := F_.
End S1.
Is this a bug or is there a deeper reason for this ?
- [Coq-Club] Inductives in Modules, Roland Zumkeller
