- To: <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club] A fault in Coq8.0?
- Date: Sun, 23 May 2004 13:07:21 +0300
The following looks for me as a fault in
Coq8.0 (I am using Windows).
Error message is issued with the command 'Qed',
when the proof of the lemma B_Cases_inv is completed:
Error: Illegal application (Type Error):
The term "B_Sym" of type "forall x y : bool, BEqual x y -> BEqual y x" cannot be applied to the terms "B_Cases0 x2 a b" : "CProp" "a" : "CProp" "B_TrueCase (R:=BEqual) (a:=a) b H1 (B_Refl a)" : "BEqual (B_Cases BEqual x2 a b) a" The 3th term has type "BEqual (B_Cases BEqual x2 a b) a" which should be coercible to "BEqual (B_Cases0 x2 a b) a" Regards,
Jevgenijs.
PS. Here is the script.
Set Implicit Arguments.
Unset Strict Implicit. Parameter bool : Type.
Parameter PROP:bool->Prop. Coercion PROP:bool >->Sortclass. Parameter BEqual : bool -> bool -> bool. Axiom B_Refl : forall x : bool, BEqual x x. Axiom B_Sym : forall x y : bool, BEqual x y -> BEqual y x. Axiom B_Trans : forall x y z : bool, BEqual x y ->BEqual y z -> BEqual x z. Parameter true : bool. Parameter false : bool. Axiom Tautology: true. Axiom Contradiction : forall x : bool, false -> x. Axiom B_Replace : forall x y : bool, BEqual x y ->x ->y. Axiom B_Decide : forall x y : bool, (BEqual x true -> y) -> (BEqual x false -> y) ->y. Parameter B_Cases: forall (R : bool -> bool -> bool), bool -> bool -> bool -> bool. Axiom B_TrueCase : forall (R : bool -> bool -> bool) (a b : bool) (x : bool), BEqual x true -> R a a ->R (B_Cases R x a b) a. Axiom B_FalseCase : forall (R : bool -> bool -> bool) (a b : bool) (x : bool), BEqual x false -> R b b -> R (B_Cases R x a b) b. Structure CSetoid : Type :=
Build_CSetoid
{cs_crr :> Type; cs_eq : cs_crr -> cs_crr -> bool}. Definition CProp := Build_CSetoid (cs_crr:=bool)
BEqual.
Definition Equal:=(fun (X:CSetoid)(x y:X)=>(cs_eq x y):CProp). Definition B_Cases0:= (fun (x a b:CProp) => (B_Cases (Equal (X:=CProp)) x a b):CProp). Lemma B_Cases_inv :
forall (x1 x2 : CProp) (a b : CProp), (BEqual x1 x2) -> (BEqual (B_Cases0 x1 a b) (B_Cases0 x2 a b)). Proof. intros x1 x2 a b H. simpl in |- *. apply B_Decide with x1. intros. apply B_Decide with x2. intros. apply B_Trans with a. unfold B_Cases0. simpl in |- *. apply B_TrueCase. assumption. apply B_Refl. apply B_Sym. unfold B_Cases0. simpl in |- *. apply B_TrueCase. assumption. apply B_Refl. intros. apply Contradiction. apply B_Replace with true. apply B_Trans with x2. apply B_Trans with x1. apply B_Sym. assumption. assumption. assumption. apply Tautology. intros. apply B_Decide with x2. intros. apply Contradiction. apply B_Replace with true. apply B_Trans with x1. apply B_Trans with x2. apply B_Sym. assumption. apply B_Sym. assumption. assumption. apply Tautology. intros. apply B_Trans with b. unfold B_Cases0. simpl in |- *. apply B_FalseCase. assumption. apply B_Refl. apply B_Sym. unfold B_Cases0. simpl in |- *. apply B_FalseCase. assumption. apply B_Refl. Qed. |
- [Coq-Club] A fault in Coq8.0?, Jevgenijs Sallinens
- Re: [Coq-Club] A fault in Coq8.0?, Hugo Herbelin
