coq-club - Re: [Coq-Club] Module problem
chronological Thread
  • From: Roland Zumkeller <Roland.Zumkeller AT polytechnique.fr>
  • To: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Module problem
  • Date: Mon, 24 May 2004 17:20:02 +0200
This was in fact the same problem that Frederique Blanqui explained in a recent post (19 mai 2004 18:11).
One solution is to place the inductive type definition outside the functor:
Inductive X_gen (V:Set) : Set :=
| Plus : V -> V -> X_gen V
| Times : V -> V -> X_gen V.
Module Interpretation_ext (I:Interpretation).
  Definition X := X_gen I.Vars.V.
Then the types X of the different functor applications are convertible.
Le 13 mai 04, à 18:45, Roland Zumkeller a écrit :
This is a simplified example that is only meant to demonstrate what I'd like to achieve.
Module Type Variables.
  Variable V : Set.
End Variables.
An interpretation associates a natural number to every variable.
Module Type Interpretation.
  Declare Module Vars : Variables.
  Variable interp : Vars.V -> nat.
End Interpretation.
The extension of an interpretation allows also to interprete sums and products:
  Inductive X : Set :=
  | Plus : I.Vars.V -> I.Vars.V -> X
  | Times : I.Vars.V -> I.Vars.V -> X.
  Definition interp_ext (x : X) :=
  match x with
  | Plus v w => I.interp v + I.interp w
  | Times v w => I.interp v * I.interp w
  end.
End Interpretation_ext.
Now, I'd like to compare two different interpretations that have the same set of variables.
Module Interp_compat (V:Variables) (I1 I2 : Interpretation with Module Vars := V).
  Module I1_ext := Interpretation_ext(I1).
  Module I2_ext := Interpretation_ext(I2).
Definition same := forall x, I1_ext.interp_ext x = I2_ext.interp_ext x.
The last definition gets rejected:
  Error: In environment
  x : I1_ext.X
The term "x" has type "I1_ext.X" while it is expected to have type "I2_ext.X"
The type X in Interpretation_ext is the same for I1_ext and I2_ext
I also tried to specify this as a constraint when defining I1 and I2 :
Module Type IntExt.
  Variable X : Set.
  Variable interp_ext : X -> nat.
End IntExt.
  Module I1_ext : IntExt := Interpretation_ext(I1).
Module I2_ext : IntExt with Definition X := I1_ext.X := Interpretation_ext(I2).
But I get the error :
  "User error: Signature components for label X do not match"
Is there a way to do this ? Of course I1.V.Vars and I2.V.Vars are the same, but can this be extended to the results of functor applications ?
thank you
