- To: Roland.Zumkeller AT polytechnique.fr
- Cc: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Re: Inductives in Modules
- Date: Mon, 24 May 2004 17:37:21 +0200 (CEST)
i encountered the same problem too. i think that inductives are not seen as
other definitions. could this be changed in a future version of coq?
--------------- previous message ------------------
Roland Zumkeller
Thu, 13 May 2004 16:27:09 +0200
I'd like to use modules to do model first-order signatures and algebras
on them :
Module Type Signature.
Variable V : Set.
Variable F : nat -> Set.
End Signature.
When defining the following module
Module S : Signature.
Inductive V : Set:= X | Y.
Inductive F : nat -> Set:= Plus : F 2 | Zero : F 0 | One : F 0.
End S.
I get this error message:
"User error: Signature components for label V do not match"
However when defining the inductive with another name first, everything
works fine.
Module S1 : Signature.
Inductive V_ : Set:= X | Y.
Definition V := V_.
Inductive F_ : nat -> Set:= Plus : F_ 2 | Zero : F_ 0 | One : F_ 0.
Definition F := F_.
End S1.
Is this a bug or is there a deeper reason for this ?
- [Coq-Club] Re: Inductives in Modules, Frederic Blanqui
- Re: [Coq-Club] Re: Inductives in Modules, Roland Zumkeller
