coq-club - [Coq-Club] IO and Coq
chronological Thread
  • From: Stefan Karrmann <sk AT mathematik.uni-ulm.de>
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] IO and Coq
  • Date: Mon, 30 Aug 2004 21:54:14 +0200
  • Mail-reply-to: <sk AT mathematik.uni-ulm.de>
If we view Coq as a programming language with
(1) dependant types
(2) terminating functions
(3) Haskell, Scheme and Ocaml as its `assembler language'
but without input and output. What is the best (or a good) way to model
input and output in Coq?
The IO monad of Haskell looks like an good starting point, but it does
not work:
Parameter IO : Set -> Set.
Parameter io_bind : forall A B:Set, IO A -> (A -> IO B) -> IO B.
Parameter io_return : forall A:Set, A -> IO A.
Definition test := return nat O.
Extraction Language Haskell.
Extract Constant IO "a" => "IO".
Extract Constant io_bind => "(>>=)".
Extract Constant io_return => "return".
Extraction "World"
   IO io_bind io_return
   test
==> The file World.hs has been created by extraction.
But World.hs contains:
module World where
import qualified Prelude
data Nat = O
           | S Nat
type IO x = () -- AXIOM TO BE REALIZED
io_bind =
  Prelude.error "AXIOM TO BE REALIZED"
io_return =
test =
  io_return O
Some ideas:
(a) The unique World approach of Clean.
(b) Encode open file descriptors etc. in a dependant type.
(c) An imperative style.
I'm using:
The Coq Proof Assistant, version 8.0 (Apr 2004)
compiled on Jun 11 2004 16:28:34
Sincerly,
Stefan
