- From: "Robert M. Solovay" <solovay AT Math.Berkeley.EDU>
- To: "Carlos.SIMPSON" <carlos AT math.unice.fr>
- Cc: Coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Some metatheoretical questions re Coq
- Date: Mon, 13 Sep 2004 22:28:33 -0700 (PDT)
Carlos,
Thanks for your comments. Some comments of mine are interspersed
below.
On Mon, 13 Sep 2004, Carlos.SIMPSON wrote:
> Hi. Some brief remarks:
> (1) Benjamin Werner also treats the first question (when Set is
> impredicative), in his thesis;
> however he only treats a truncated version of the Type hierarchy,
> i.e. he has sorts Prop, Set and Type_1. Thus, technically speaking this
> doesn't answer the question for the case of
> an arbitrary finite number of sorts Type_i (which is what Coq
> implements). Also there are some differences between the
> system he considers and the present version of Coq, notably the new
> eqT_rect and false_rect; and on the other hand he
> treats eta-conversion which apparently is not implemented now. And on
> the whole it is already a lot of hard work!
I'm not clear what result Werner proved here. Does he prove the
consistency of Coq with impredicative Set in some orthodox system of
set-theory [like the system ZFC + "There are infinitely many
inaccessibles" of my prior letter?
[snip]
> (3) for the question about formulae in TT, to make it precise you would
> need to specify what is an allowable ``way of translating formulae into
> Coq''.
My knowledge of Coq is, at the moment, quite rudimentary. But I
would have thought there is an obvious translation:
(a) There is a development of the natural numbers in Coq.
(b) Treat subsets of X as just functions from X to 2.
(c) I forget whether I said logic should be classical when I posed
the question. But certainly this is the case I am interested in. In this
case, the translation of quantifers and propositional connectives seems
unproblematic.
Are there subtleties I am missing here?
> I would appreciate getting a CC of any emails on this subject which are
> not posted directly to coq_club...Thanks!
> ---Carlos Simpson
Will do.
--Bob Solovay
- [Coq-Club] Some metatheoretical questions re Coq, Robert M. Solovay
- Re: [Coq-Club] Some metatheoretical questions re Coq,
Carlos.SIMPSON
- Re: [Coq-Club] Some metatheoretical questions re Coq, Robert M. Solovay
- Re: [Coq-Club] Some metatheoretical questions re Coq, Benjamin Werner
Carlos.SIMPSON
