coq-club - [Coq-Club] Theory of PTSs
chronological Thread
  • To: Coq Club <Coq-club AT pauillac.inria.fr>
  • Subject: [Coq-Club] Theory of PTSs
  • Date: Fri, 24 Sep 2004 15:39:36 +0100 (BST)
I am currently working on a formalisation of the metatheory of Pure Type
Systems in Coq, using a nested data type to represent the terms:
Inductive term : Set -> Type :=
  var : forall V : Set, V -> term V |
  srt : forall V : Set, sort -> term V |
  app : forall V : Set, term V -> term V -> term V |
  pi  : forall V : Set, term V -> term (maybe V) -> term V |
  lda : forall V : Set, term V -> term (maybe V) -> term V.
Thus, term V is the type of all terms that can be formed using the objects
of V as free variables (and the objects of sort as sorts). This idea first
appeared, as far as I am aware, in Bird and Paterson's paper "de Bruijn
Notation as a Nested Datatype" (Journal of Functional Programming 9(1):
77--91, 1999).
(In fact, to keep everything within Set, I am using a slight variation on
the above definition.
Inductive term : nat -> Set :=
  var :> forall n : nat, fin n -> term n |
  srt : forall n : nat, sort -> term n |
  app : forall n : nat, term n -> term n -> term n |
  pi : forall n : nat, term n -> term (S n) -> term n |
  lda : forall n : nat, term n -> term (S n) -> term n.)
From what little I've done so far, this approach seems far easier to work
with than the other two methods of which I am aware: Pollack's "The Theory
of LEGO", using concrete terms with separate types for the bound variables
and free variables (parameters); and Barras's project "Coq in Coq", which
uses the natural numbers as de Bruijn indices.
But I am wary that I might simply be repeating someone else's work.  Does
anyone know of any formalisations of the metatheory of a type theory in
some proof checker following this approach?
Robin Adams
