coq-club - Re: [Coq-Club] Some questions on reduction tactics
chronological Thread
  • To: Jasper Stein <J.Stein AT cs.ru.nl>
  • Cc: "coq-club AT pauillac.inria.fr" <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Some questions on reduction tactics
  • Date: Thu, 14 Oct 2004 13:52:26 +0200
On Thu, Oct 14, 2004 at 10:09:20AM +0200, Jasper Stein wrote:
> Also. How is the zeta flag supposed to work? I get
> Eval cbv zeta in (let (a,b):=(conj I I) in a).
>      = let (a, _) := conj I I in a
>      : True
> while I was expecting the answer "=I : True".
You need to throw in iota-reduction: conj is a constructor of an
inductive type, the reduction that "attacks" this is iota. Your let is
not quite "just" a local definition, it is a destructive let; you
destroy the conj to give names to its two subterms. That's actually
alternative syntax for case analysis when there is only one case
(section 1.2.13 of manual).
Compare with:
Coq < Eval cbv zeta in (let a:=(conj I I) in a).
     = conj I I
     : True /\ True
> Then. I see "simpl" is supposed to do beta iota, then delta, and then
> another
> beta iota. How do I know which constants get unfolded by the delta bit?
> When
> I do
> Eval simpl in (sweep_rows Qm_2_2_is_one).
> I get an immediate answer, while doing
> Eval cbv beta iota delta beta iota in (sweep_rows Qm_2_2_is_one).
> seems to loop (even without the second beta iota flags).
This is different:
Cbv foo bar
does foo-bar normalisation, not foo-normalisation and then
bar-normalisation. The flags of Cbv form a set, not a list. It meant
it works until neither a foo step, nor a bar step can be done.
simpl is (from what you say) supposed to be:
cbv beta iota; cbv delta; cbv beta iota.
This is different from cbv beta iota delta: In the former, the result
is a beta-iota normal form, but not necessarily a delta-normal
form. If the "last" beta-iota step creates a delta-redex, this
delta-redex is not reduced, while it is with the latter.
> Finally. Is there a way to do something like Eval (red;hnf) in expr. or
> Eval
> unfold const in (Eval simpl in expr).  ...?
"unfold" is simply delta-reduction, isn't it? I'd expect:
Eval cbv delta [const] in (Term)
to do the job.
Lionel
