- To: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] The Omega module
- Date: Mon, 18 Oct 2004 13:29:00 +0200
Hi,
I guess the Omega module adds some new hints in the zarith hint base,
and as for any other module, it may or may not be clearly documented.
Anyway, to make the omega tactic solve your goal when hypotheses are
inconsistant, you could do
casetype False; omega.
- Claude
>>>>> "Brian" == Brian Emre Aydemir
>>>>>Â <baydemir AT cis.upenn.edu>
>>>>> writes:
Brian> Hi,
Brian> I have noticed the following behavior about the Omega module.
Brian> Sometimes I have a subgoal where the equality is a conclusion on
Brian> something other than terms of type nat or Z, and where the
hypotheses
Brian> include (n < k) and (n >= k) for n and k arbitrary natural numbers
(a
Brian> contradiction that makes the subgoal trivially true).
Brian> "auto with *" fails to do anything. So then I try including the
Omega
Brian> module. "omega" fails to solve the subgoal (it complains about
the
Brian> equality). However, now "auto with *" will solve it! It seems
that
Brian> the Omega module modifies the resources used by the auto tactic.
I
Brian> discovered this by accident. Is this behavior documented
anywhere? I
Brian> couldn't find anything after looking in the Coq reference manual,
Brian> specifically Chapter 17, for information on Omega.
Brian> Cheers,
Brian> Brian
Brian> --
Brian> Brian Emre Aydemir
Brian> http://www.cis.upenn.edu/~baydemir/
Brian> --------------------------------------------------------
Brian> Bug reports: http://coq.inria.fr/bin/coq-bugs
Brian> Archives: http://pauillac.inria.fr/pipermail/coq-club
Brian> http://pauillac.inria.fr/bin/wilma/coq-club
Brian> Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
| Claude Marché |
mailto:Claude.Marche AT lri.fr
| LRI - Bât. 490 | http://www.lri.fr/~marche/ |
| Université de Paris-Sud | phoneto: +33 1 69 15 64 85 |
| F-91405 ORSAY Cedex | faxto: +33 1 69 15 65 86 |
- [Coq-Club] The Omega module, Brian Emre Aydemir
- Re: [Coq-Club] The Omega module, Claude Marche
- Re: [Coq-Club] The Omega module, Brian Emre Aydemir
