coq-club - [Coq-Club] Generalization in Sections
chronological Thread
  • To: <coq-club AT pauillac.inria.fr>
  • Subject: [Coq-Club] Generalization in Sections
  • Date: Tue, 26 Oct 2004 12:55:10 +0200
Hello,
In the two examples below I see different behaviour of Coq when it generalizes Hypotheses in a section after it was closed:
Section X.
Variable k:nat.
Hypothesis pos_k: 0<k.
Axiom Test_X:forall P:nat-> Prop, 0<k .
End X.
Section Y.
Variable k:nat.
Lemma Test_Y:forall P:nat-> Prop, 0<k .
intros.
assumption.
Save.
End Y.
It seems that because the Hypothesis pos_k in section X is not used, it is not generalized:
Check Test_X.
> Test_X
>  : forall k : nat, (nat -> Prop) -> 0 < k
Check Test_Y.
> Test_X
>  : forall k : nat, 0 < k -> (nat -> Prop) -> 0 < k
Is there a way to force Coq to generalize hypotheses that are not used so that the type of Test_X becomes the same as that of Test_Y without actually using pos_k in a proof?
Thanks in advance,
Georgi
