- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] an useful tactic ?
- Date: Wed, 24 Nov 2004 13:13:32 +0100 (MET)
Hi all
Each time I reach a goal like (f a b ... = f c d ...) and I know that the arguments can be proved pairwise equal, it always takes me some time to remember the proper use of the lemmas a la f_equal, with their implicits arguments. So last time I designed some ltac code to take care of these
situations. Maybe this can interest others ?
The first try:
Ltac equal :=
match goal with
| |- ?f _ = ?f _ => apply f_equal with (f:=f)
| |- ?f _ _ = ?f _ _=> apply f_equal2 with (f:=f)
| |- ?f _ _ _ = ?f _ _ _ => apply f_equal3 with (f:=f)
| |- ?f _ _ _ _ = ?f _ _ _ _=> apply f_equal4 with (f:=f)
| |- ?f _ _ _ _ _ = ?f _ _ _ _ _ => apply f_equal5 with (f:=f)
| _ => idtac
end.
This simple code works ok for simple situations, more precisely when there is no dependency in the type of f. But the exact goal I was trying to solve was (a,b)=(c,d), that is (pair A B a b)=(pair A B c d). Here is a (ugly) version that can handle that, based on the proofs of f_equal* :
Ltac equal :=
let des := destruct 1 || intro in
let r := try reflexivity in
match goal with
| |- ?f ?a = ?f' ?a' => cut (a=a'); des; r
| |- ?f ?a ?b = ?f' ?a' ?b' =>
cut (b=b');[cut (a=a');[do 2 des; r|r]|r]
| |- ?f ?a ?b ?c = ?f' ?a' ?b' ?c'=>
cut (c=c');[cut (b=b');[cut (a=a');[do 3 des; r|r]|r]|r]
| |- ?f ?a ?b ?c ?d= ?f' ?a' ?b' ?c' ?d'=>
cut (d=d');[cut (c=c');[cut (b=b');[cut (a=a');[do 4 des; r|r]|r]|r]|r]
| |- ?f ?a ?b ?c ?d ?e= ?f' ?a' ?b' ?c' ?d' ?e'=>
cut (e=e');[cut (d=d');[cut (c=c');[cut (b=b');[cut (a=a');[do 5 des;
r|r]|r]|r]|r]|r]
| _ => idtac
end.
One example:
Require Import ArithRing.
Lemma demo_equal : forall x y, (x*2,y*2)=(x+x,y+y).
intros.
equal.
ring.
ring.
Qed.
- [Coq-Club] an useful tactic ?, Pierre Letouzey
