coq-club - Re: [Coq-Club] beginner's question
chronological Thread
  • From: Brian Emre Aydemir <baydemir AT cis.upenn.edu>
  • To: Robert Dockins <robdockins AT fastmail.fm>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] beginner's question
  • Date: Sat, 8 Jan 2005 12:57:56 -0500
On Jan 7, 2005, at 22:01, Robert Dockins wrote:
I am new to coq and I'm trying to get my feet wet by doing some proofs from _Types and Programming Languages_ by Pierce. [...] My question is, how is the best way to go about defining "the smallest binary relation such that..." in coq?
Relations can be defined inductively much as you defined the set of terms inductively. For example, the following code snippet defines the evaluation relation.
==== BEGIN CODE ====
Reserved Notation "A --> B" (at level 40, left associativity).
Inductive evalsTo : term -> term -> Prop :=
  | EIfTrue:  forall (x y:term), (If True x y) --> x
  | EIfFalse: forall (x y:term), (If False x y) --> y
  | EIf: forall (a b x y:term),
      (a --> b) ->
      ((If a x y) --> (If b x y))
where "A --> B" := (evalsTo A B).
==== END CODE ====
This seems to work pretty well in practice. In particular, you now get an induction principle for the evaluation relation.
Cheers,
Brian
Brian Emre Aydemir
http://www.cis.upenn.edu/~baydemir/
