- From: Pierre Courtieu <Pierre.Courtieu AT univ-orleans.fr>
- To: Lionel Elie Mamane <lionel AT mamane.lu>
- Cc: Venanzio Capretta <Venanzio.Capretta AT mathstat.uottawa.ca>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] impredicative with CoqIde
- Date: Mon, 10 Jan 2005 09:55:01 +0100
On 10 jan 2005, Lionel Elie Mamane wrote:
> On Fri, Jan 07, 2005 at 08:10:35AM -0500, Venanzio Capretta wrote:
> > how can I specify the option -impredicative-set when using
> > ProofGeneral?
> Menu "Proof-General", advanced, customize, coq, coq prog name. There,
> add all options you want, set, save. Then menu "coq", "exit coq".
If you do not want to do this each time you open your file, put this at its
end (complete with other options):
*** Local Variables: ***
*** coq-prog-name: "coqtop -I . -emacs -impredicative-set" ***
*** End: ***
Pierre Courtieu
- [Coq-Club] impredicative with CoqIde, Venanzio Capretta
- Re: [Coq-Club] impredicative with CoqIde, Jean-Christophe Filliatre
- [Coq-Club] Re: impredicative with CoqIde,
Stefan Monnier
- Re: [Coq-Club] Re: impredicative with CoqIde,
Pierre Casteran
Pierre Courtieu
Stefan Monnier
- Re: [Coq-Club] Re: impredicative with CoqIde, Pierre Courtieu
Stefan Monnier
- [Coq-Club] Re: impredicative with CoqIde, Stefan Monnier
Pierre Courtieu
Pierre Casteran
Lionel Elie Mamane
- Re: [Coq-Club] impredicative with CoqIde, Pierre Courtieu
