- From: David Pichardie <david.pichardie AT irisa.fr>
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] How can I use functors inside Module Type ?
- Date: Fri, 21 Jan 2005 09:22:31 +0100
Hi,
My problem is in Module Type T3 below.
Module Type T1.
Parameter A : Set.
Parameter a : A.
End T1.
Module Type T2 (M1:T1).
Parameter f : M1.A -> M1.A.
End T2.
Module Type T3 (M1:T1) (M2:T2).
Parameter prop : M2(M1).f M1.a = M1.a.
(* doesn' work ! *)
(* I've tried to add
Declare Module M' := M2(M1)
But i receive "Only simple modules allowed in module declarations"... *)
End T3.
I there a way to do similar things with the Coq module system ?
Thanks,
David Pichardie
http://www.irisa.fr/lande/pichardie/index.en.html
- [Coq-Club] How can I use functors inside Module Type ?, David Pichardie
