coq-club - Re: [Coq-Club] module question
chronological Thread
  • From: Pierre Casteran <pierre.casteran AT labri.fr>
  • To: anoun AT labri.fr
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] module question
  • Date: Tue, 8 Feb 2005 15:11:15 +0100
Selon Houda Anoun
<anoun AT labri.fr>:
Hi Houda.
 May be that the problems comes from the use of two kinds of polymorphism
(one with dependent product (ML-like), and functor polymorphism).
I don't know if the following example will help you, but here is
a definition of a module type for Comparable sets, and a functor
which build (comparable) formulae.
It is highly incomplete wrt to your goals, but I hope it can help
a little.
Pierre
(* Totally ordered set *)
Module Type TOSET.
 Parameter t : Set.
 Parameter compare : t -> t -> comparison.
 Axiom compare_eq : forall a b, compare a b = Eq -> a = b.
 Axiom compare_eq2 : forall a, compare a a = Eq.
End TOSET.
(* Simple formulae *)
Module Form (T:TOSET) <: TOSET.
 Inductive form : Set :=
   atom : T.t -> form
 | impl : form -> form -> form.
 Definition t := form.
 Fixpoint compare (f1 f2:t){struct f1}: comparison :=
  match (f1,f2) with (atom a1, atom a2) => T.compare a1 a2
                   | (impl f1 f2, impl f3 f4) =>
                          (match compare f1 f3 with Lt => Lt
                                                    | Gt => Gt
                                                    | Eq =>
                                                      compare f2 f4
                           end)
                   | (atom a, impl f3 f4)=> Lt
                   | (_,_)               => Gt
  end.
 Theorem  compare_eq : forall a b, compare a b = Eq -> a = b.
 Proof.
  induction a; destruct b.
  unfold compare.
 intro;  rewrite  (T.compare_eq t0 t1); auto.
 simpl.
 discriminate 1.
 simpl;discriminate 1.
 simpl.
 (* thank you Yves *)
 Ltac caseEq f := generalize (refl_equal f); pattern f at -1; case f.
 caseEq (compare a1 b1); caseEq (compare a2 b2); try discriminate 3.
 intros H0 H1;rewrite (IHa1 b1 H1);rewrite (IHa2 b2 H0); auto.
Qed.
Lemma compare_eq2 : forall a, compare a a  = Eq.
Proof.
 induction a.
 unfold compare;rewrite (T.compare_eq2 t0);auto.
 simpl;rewrite IHa1.
 rewrite IHa2.
 auto.
Qed.
End Form.
Pierre Casteran
(+33) 540006931
This message was sent using IMP, the Internet Messaging Program.
