- From: Pierre Casteran <pierre.casteran AT labri.fr>
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Example of functor type
- Date: Fri, 18 Feb 2005 09:05:56 +0100
Hello,
I am looking for a (simple if possible) example of a functor type
(as created with "Module Type ident module_bindings := module_type")
and how to apply this functor.
By the way, it is possible that the following is a bad use of
functor types :-(
Pierre
Module Type S1.
Parameter t : Set.
Parameter eq_dec : forall a b:t, {a=b}+{a<>b}.
End S1.
Module Type S2 (M:S1).
Definition t := M.t.
Definition eq_dec := M.eq_dec.
Parameter eq_dec_prop : forall a b:t, a = b \/ a <> b.
End S2.
all the following commands raise errors.
Module F1_2 (M:S1) : S2.
Module F1_2 (M:S1) : S2 with Module M:=M.
Module F1_2 (M:S1) : S2 M.
Module F1_2 (M:S1) : (S2 M).
Pierre Casteran
(+33) 540006931
This message was sent using IMP, the Internet Messaging Program.
- [Coq-Club] Example of functor type, Pierre Casteran
- Re: [Coq-Club] Example of functor type, Claudio Sacerdoti Coen
