- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Beginner question: stuck on simple proof.
- Date: Fri, 25 Feb 2005 12:30:49 -0500
Hello,
I'm working my way through Coq'Art and applying the concepts to prove simple results from the text Types and Programming Languages. I am stuck trying to prove the following trivial result about boolean programs: a term in normal form implies the term is a value. Here is the development:
Inductive term : Set :=
| ETrue : term
| EFalse : term
| If : term -> term -> term -> term.
(* The single step reduction relation, --> *)
Inductive red1 : term -> term -> Prop :=
| E_IfTrue : forall t2 t3 : term, (red1 (If ETrue t2 t3) t2)
| E_IfFalse : forall t2 t3 : term, (red1 (If EFalse t2 t3) t3)
| E_If : forall t1 t1': term, (red1 t1 t1') ->
(forall t2 t3 : term, (red1 (If t1 t2 t3) (If t1' t2 t3))).
Definition normal_form (t : term) := ~(ex term (fun t':term => red1 t t')).
Definition value (t : term) := t=ETrue \/ t=EFalse.
Theorem normal_implies_value : forall t, (normal_form t) -> (value t).
The proof should go by case analysis on t, and it easy to show that when t is ETrue or EFalse that the result holds:
unfold value, normal_form, not.
intro t.
case t.
intro H; left; reflexivity.
intro H; right; reflexivity.
However I can't seem to show the remaining case. Could someone comment on how to obtain this result? Also, is there an alternative formulation of normal_form, mine strikes me as awkward? Finally, is there a more appropriate forum for asking these sorts of beginner questions?
Thanks,
David
- [Coq-Club] Beginner question: stuck on simple proof., David Van Horn
- Re: [Coq-Club] Beginner question: stuck on simple proof., Pierre Casteran
- Re: [Coq-Club] Beginner question: stuck on simple proof., Robert Dockins
