- From: Guillaume Melquiond <guillaume.melquiond AT ens-lyon.fr>
- To: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] A more powerful "apply" tactic?
- Date: Tue, 01 Mar 2005 13:08:19 +0100
Le jeudi 24 février 2005 à 23:53 +0100, Roland Zumkeller a écrit :
> > Variable A : Set.
> > Variable f : A -> A -> A.
> > Variable P : A -> Prop.
> > Variable T : forall x y : A, P (f x y) -> P (f y x).
> > Variables a b : A.
> > Definition d := (f a b).
> > Definition e := (f b a).
> > Axiom K : P d.
> > Lemma L : P e.
> > apply T with (1 := K).
> > Error: The term "K" has type "P d" while it is expected to have type
> > "P (f ?7 ?8)"
> > - Is there another tactic I could use instead of "apply"?
> Not a different tactic, but inference of implicit arguments:
> apply(T _ _ K).
Thanks a lot for this suggestion. It indeed works, without having to
supply all the arguments as in "K: P (f a b)".
> "apply ... with" cannot always be translated to (and thus not
> implemented by) this mechanism, since there might be arguments that
> cannot be derived, e.g. in apply T with (y := a).
I'm not sure to understand why "apply T with (1:=K)" could not work like
"apply (T _ _ K)". Or maybe you are talking about a situation a lot more
general than just "apply something with (1:=first) (2:=second) ..."?
I was also suggested off-list to use "Notation" instead of "Definition".
It also works just fine and doesn't require me to always know the number
of "_" I have to put before each theorem in the script. I was wondering
about the complexity of such a change for Coq though. For example,
-tion b := (f a a).
-tion c := (f b b).
-tion d := (f c c).
-tion e := (f d d).
Does anybody know what the space and time complexities are, depending on
whether "Definition" or "Notation" is used? My non-educated guess would
be that "Definition" leads to a linear behavior, while "Notation" is
exponential. But maybe I'm just overly pessimistic and "Notation" also
has a linear behavior. Which one is it?
Best regards,
Guillaume
- Re: [Coq-Club] A more powerful "apply" tactic?, Guillaume Melquiond
