- From: Stefan Karrmann <sk AT mathematik.uni-ulm.de>
- To: Coq Club <coq-club AT pauillac.inria.fr>
- Cc: roconnor AT theorem.ca
- Subject: Re: [Coq-Club] Question about Modules.
- Date: Sun, 13 Mar 2005 21:25:30 +0100
Dear Russel,
an alternative to modules is Structure (aka Record). They give you first
class values. I use the modules only to split the namespace. (Note that each
file is a module on its own - try: Require Bool. Print Bool. !)
Then your example looks like:
(** new file Field.v *)
Structure Field : Type :=
{ K :> Set
; plus : K -> K -> K
(** coqc Field.v *)
(** new file VectorSpace.v *)
Require Import Field. (* You may choose Export instead of Import. *)
Structure VectorSpace (F:Field) : Type :=
{ V :> Set
; plus : V -> V -> V
; scale : K F -> V -> V
(** coqc VectorSpace.v *)
(** new file DualSpace.v *)
Require Import VectorSpace.
Definition DualSpace (F:Field) (X:VectorSpace F) : VectorSpace F :=
Build_VectorSPace F { f:V X -> K F | linear f } (* ... *)
PS: A nice scheme for structures is imho:
Record is_X (...) : Prop := { x : Prop ... }.
Structure > X : Type := { C :> Type ; functions ; proof : is_X ... }.
It separates the consistency proof from the types and functions of the
structure.
E.g.:
Set Implicit Arguments.
Record is_setoid (C:Type) (Ceq : relation C) : Prop :=
{ refl : reflexive C Ceq
; sym : symmetric C Ceq
; trans : transitive C Ceq
Structure > setoid : Type :=
{ C :> Type
; Ceq : relation C
; proof : is_setoid Ceq
Note the indications for coercions, i.e. `>' and `:>'. This allows us to
write:
Let x : is_setoid Ceq := Build_is_setoid C_refl C_sym C_trans.
Let y : setoid := x.
Let z (c:y) : Prop := Ceq y c c.
After the commands:
Implicit Arguments Ceq [s]. (* Make the setoid implicit! *)
Infix "[=]" := Ceq (at level 70, no associativity).
We can even write:
Let z' (c:y) : Prop := c [=] c.
(Sat, Mar 12, 2005 at 12:58:20PM -0500):
> I am trying to understand Coq's Module system. I want to do something
> analogous to having a Module Type for fields. Having a Module Type for
> vector spaces with a field parameter, and having a Fuctor taking a vector
> space to the dual vector space.
> Module Type Field.
> Parameter K:Set.
> Parameter plus: K -> K -> K.
> End Field.
> Module Type VectorSpace (F:Field).
> Parameter V:Set.
> Parameter plus: V -> V -> V.
> Parameter scale: F.K -> V -> V.
> End VectorSpace.
> Module DualSpace (F:Field) (V:VectorSpace F) : VectorSpace F.
> Definition V := {f:V.V->F.K | linear f}
> End DualSpace.
> Coq complains at my definition of DualSpace. It is entirely possible I
> have no idea what I am doing.
Best regards,
Stefan Karrmann
- [Coq-Club] Question about Modules., roconnor
- Re: [Coq-Club] Question about Modules.,
anoun
Robert Dockins
- Re: [Coq-Club] Question about Modules., Pierre Casteran
Robert Dockins
- Re: [Coq-Club] Question about Modules., Stefan Karrmann
Carlos.SIMPSON
- Re: [Coq-Club] Question about Modules., Hugo Herbelin
anoun
