- From: Hugo Herbelin <herbelin AT pauillac.inria.fr>
- To: David.Monniaux AT ens.fr (David Monniaux)
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] induction on arbitrary-arity trees
- Date: Thu, 31 Mar 2005 13:21:45 +0200 (MET DST)
Hi,
> I have the following definition:
> Inductive comp_widening_chain (S : Set) : Set :=
> comp_widening_chain_intro : forall x : S,
> (forall y : S,
> (option (comp_widening_chain S))) -> (comp_widening_chain S).
> If I try to do reasonings by induction using the "induction" or "elim"
> on such a datatype, I don't get an induction hypothesis.
This is because "induction" and "elim" relies on the automatically
defined schemas "comp_widening_chain_rect", "comp_widening_chain_rec"
and "comp_widening_chain_ind" and the algorithm used to build these
schemas is not clever enough to know what to do with the "option"
type.
You have to define the induction scheme by yourself, e.g. as follows:
Definition option_fold (A:Set) (B:Type) (f:A->B) (b:B) o :=
match o with
| None => b
| Some x => f x
end.
Implicit Arguments option_fold [A B].
Definition comp_widening_chain_rect'
(S:Set)
(P : comp_widening_chain S -> Type)
(f : forall (x:S) (c: S -> option (comp_widening_chain S)),
(forall y:S, option_fold P True (c y)) ->
P (comp_widening_chain_intro S x c))
fix F (c : comp_widening_chain S) : P c :=
match c return (P c) with
| comp_widening_chain_intro x d =>
f x d (fun y =>
match d y as z return option_fold P True z with
| None => I
| Some x => F x
end)
end.
and then use "induction ... using comp_widening_chain_rect'".
Alternatively, using refine is a priori not a bad idea.
Alternatively, you can redefine your inductive type as follows
Inductive comp_widening_chain_opt (S : Set) : Set :=
| comp_widening_chain_none : (comp_widening_chain_opt S)
| comp_widening_chain_some (x : S) :
(forall y : S, comp_widening_chain_opt S) -> (comp_widening_chain_opt S).
(forall y : S, comp_widening_chain_opt S) -> (comp_widening_chain S).
but that probably was not the objective.
Best regards,
Hugo Herbelin
- [Coq-Club] induction on arbitrary-arity trees, David Monniaux
- Re: [Coq-Club] induction on arbitrary-arity trees, Christine Paulin
- Re: [Coq-Club] induction on arbitrary-arity trees, Hugo Herbelin
