- To: Pierre Casteran <pierre.casteran AT labri.fr>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] unfold and apply
- Date: Thu, 7 Apr 2005 08:41:57 -0400 (EDT)
On Thu, 7 Apr 2005, Pierre Casteran wrote:
> Hello,
> Sometimes apply and constant unfolding don't cooperate as I expect.
> Let us take a simplified example.
> Inductive T2 : Set :=
> zero : T2
> | cons : T2 -> T2 -> nat -> T2 -> T2.
> Definition psi (alpha beta:T2) := cons alpha beta 0 zero.
> Parameter lt : T2 -> T2 -> Prop.
> Axiom b_lt_psi_ab : forall a b , lt b (psi a b).
> Let us assume I want to solve the following goal :
> Goal forall a b , lt b (cons a b 0 zero).
> intros; apply b_lt_psi_ab.
> Toplevel input, characters 581-598
> Error: Impossible to unify "lt ?4 (psi ?3 ?4)" with "lt b (cons a b 0 zero)"
Perhaps use the following:
intros.
refine (b_lt_psi_ab _ _).
Qed.
or if you want something a yucky, but a bit more general:
Ltac use e :=
first
[refine (e)
|refine (e _)
|refine (e _ _)
|refine (e _ _ _)
|refine (e _ _ _ _)
|refine (e _ _ _ _ _)
|refine (e _ _ _ _ _ _)
|refine (e _ _ _ _ _ _ _)
|refine (e _ _ _ _ _ _ _ _)
|refine (e _ _ _ _ _ _ _ _ _)].
intros.
use b_lt_psi_ab.
Qed.
Russell O'Connor <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
- [Coq-Club] unfold and apply, Pierre Casteran
- Re: [Coq-Club] unfold and apply, Pierre Casteran
- Re: [Coq-Club] unfold and apply, roconnor
