coq-club - Re: [Coq-Club] proving an induction principle on even numbers
chronological Thread
  • From: Roland Zumkeller <Roland.Zumkeller AT polytechnique.fr>
  • To: Aaron Bohannon <bohannon AT cis.upenn.edu>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] proving an induction principle on even numbers
  • Date: Thu, 7 Apr 2005 20:05:11 +0200
Hi,
it seems that proof irrelevance is not yet needed for this induction principle.
Inductive even : nat -> Prop :=
  | zero_even : even O
  | ss_even : forall n : nat, even n -> even (S (S n)).
Definition even_nat := {n : nat | even n}.
Definition exist_even := exist (fun x : nat => even x).
Definition even_O : even_nat := exist_even O zero_even.
Definition even_SS (en : even_nat) : even_nat :=
  match en with
  exist n p => exist_even (S (S n)) (ss_even n p)
  end.
Lemma even_nat_ind :
  forall P : even_nat -> Prop,
  P even_O ->
  (forall en : even_nat, P en -> P (even_SS en)) ->
  forall en : even_nat, P en.
Proof.
destruct en.
generalize x e; clear x e.
refine(
fix ind (x:nat) (e:even x) {struct e} : P (exist (fun n=>even n) x e) :=
  match e as e' in even x' return P (exist (fun n=>even n) x' e') with
  | zero_even => _
  | ss_even x xe => _
  end).
exact H.
apply(H0 (exist_even x0 xe)).
apply ind.
Qed.
But I agree with Benjamin that you'll run into trouble later for the reason he explained.
As pointed out proof irrelevance can be proven explicitly for your predicate.
It can also be made implicit by defining "even" in a different way:
Fixpoint even (n:nat) : Prop := match n with
| 0 => True
| S 0 => False
| S (S n) => even n
end.
Now all the proofs of even are convertible !
Definition even_nat := sig even.
Definition even_O : even_nat := exist even O I.
  match en with
  exist n p => exist even (S (S n)) p
  end.
Your induction principle can now be proven by induction over the certificate of being even (i.e. the half).
Require Import Omega.
Lemma even_is_double : forall a, even a -> exists i, i*2 = a.
cut(forall n a, a < n ->even a -> exists i, i*2 = a).
  intros.
  apply H with (n:=S (S a)); auto.
induction n; intros.
  inversion H.
destruct a.
  exists 0; apply refl_equal.
destruct a.
  inversion H0.
destruct(fun X => IHn a X H0).
  omega.
exists (S x).
  simpl; rewrite H1; apply refl_equal.
Defined.
Lemma true_unique : forall P (a:True), P I -> P a.
intros.
exact(match a as a' return P a' with I => X end).
Qed.
  P even_O ->
destruct en.
destruct(even_is_double x e) as [i Hi].
generalize e; clear e; rewrite <- Hi; clear Hi; intros.
induction i; simpl.
pattern e; apply true_unique.
exact H.
apply (H0 (exist even (i*2) e)).
apply IHi.
Qed.
Good luck !
Roland
http://www.lix.polytechnique.fr/~zumkeller/
