coq-club - Re: [Coq-Club] functional induction
chronological Thread
  • From: Pierre Courtieu <Pierre.Courtieu AT univ-orleans.fr>
  • To: "Hao-yang Wang" <hywang AT pobox.com>
  • Cc: <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] functional induction
  • Date: Mon, 9 May 2005 13:38:21 +0200
On 06 mai 2005, Hao-yang Wang wrote:
> With the following function:
> Fixpoint sep (A:Set) (f:A->A) (a:A) (z:list A) {struct z}: list A :=
>      match z with
>      | nil => nil
>      | x::nil => x::nil
>      | x::(y::zs) as z1 => x::a::sep A f a z1
>      end.
> The tactic "functional induction sep A f x xs" works nicely in proving
> the following theorem:
>     Theorem map_sep: forall A f x xs,
>         map f (sep A f x xs) = sep A f (f x) (map f xs).
> However, if I remove the parameter "f" from the above definition of sep,
> functional induction would emit a typing error.
This is due to a limitation of the tactic: variable put in argument of
functional induction are duplicated (as with the induction tactic).
Therefore A is duplicated into A0, and (f x) has not the right type. You
need to let f inside the goal (do not intro it) when you do functional
induction:
Theorem map_sep: forall A x xs f, map f (sep A x xs) = sep A (f x) (map f xs).
  intros A x xs. (* let f in the goal *)
  functional induction sep A x xs.
Cheers,
Pierre Courtieu
