- From: Pierre Casteran <pierre.casteran AT labri.fr>
- To: Venanzio Capretta <Venanzio.Capretta AT mathstat.uottawa.ca>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] CoFixpoint with
- Date: Wed, 18 May 2005 08:12:35 +0200
Selon Venanzio Capretta
<Venanzio.Capretta AT mathstat.uottawa.ca>:
> Hi,
> When I define two terms by mutual corecursion, I seem to get the wrong
> reductions when doing the proofs and strange errors at the end of the proof.
> In the attached example I define a coinductve type of binary trees and
> then two trees by mutual corecursion:
> inf_l = node inf_r leaf
> inf_r = node leaf inf_l
> When I try to prove something about them, inf_l is unfolded not as (node
> inf_r leaf) as expected, but as (node inf_l leaf), which is wrong.
> Fortunately (?!) at the end of a proof that exploits this wrong
> unfolding, Coq rejects the final term.
> Notice that the proof of inf_l_unfold is not by coinduction, so I expect
> that when I have the message "Proof completed." I can "Qed" safely.
> Instead I get a type-checking error.
> This appears to be a bug in the implementation of "CoFixpoint ... with ...".
> Is there a way around it?
Hi Venanzio,
Yes, it seems to be a problem with the CoFixpoint ... with construct.
Your example works perfectly if you replace the mutual cofixpoint
with a function with a boolean parameter :
CoFixpoint zigzag (b:bool) :tree :=
if b then node (zigzag false) leaf
else node leaf (zigzag true).
Lemma unfold_l : zigzag true = node (zigzag false) leaf.
Proof.
rewrite (tree_decompose (zigzag true)).
simpl.
trivial.
Qed.
Lemma Infinite_lr : forall b, Infinite (zigzag b).
cofix H.
intro b; case b; rewrite tree_decompose; simpl.
constructor 1.
auto.
constructor 2;auto.
Qed.
Notice that with Coq 8.0pl2, The first lemma :
(* I shouldn't be able to prove this. *)
Lemma inf_l_unfold: inf_l = node inf_l leaf.
Proof.
pattern inf_l at 1.
rewrite tree_decompose.
simpl.
apply refl_equal.
Could not be proved (an error message occurred at the tactic call
"apply refl_equal").
Cheers,
Pierre
> Venanzio
> Venanzio Capretta
> Department of Mathematics
> and Statistics
> University of Ottawa, Canada
> http://www.science.uottawa.ca/~vcapr396/
Pierre Casteran
http://www.labri.fr/Perso/~casteran/
(+33) 540006931
This message was sent using IMP, the Internet Messaging Program.
- [Coq-Club] CoFixpoint with, Venanzio Capretta
- Re: [Coq-Club] CoFixpoint with, Pierre Casteran
Venanzio Capretta
- Re: [Coq-Club] CoFixpoint with, Frederic . Blanqui
Venanzio Capretta
