coq-club - [Coq-Club] Re: Unicode Notations
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] Re: Unicode Notations
  • Date: Thu, 26 May 2005 16:00:35 -0400
  • Cancel-lock: sha1:hcSbPnLps3irvsQbubIiYmZMSVw=
>> As far as I know, coq does not support the \uXXXX escape sequences,
>> but CoqIDE allows to input them directly : type CONTROL+SHIFT+211A and
>> you will see a marvellous bold math Q (if the font supports it...)
> Sorry I should have been more clear.  I've entered these characters
> together with ctrl+shift as you say.  The notation is accepted, but you
> cannot use it.  Coq seems to refuse to allow two unicode charaters to make
> one token.  Maybe it is a CamlP4 thing.
I've had similar problems but even with just single-unicode-char tokens.
E.g. I had no problem making notations using λ, Λ, ∀, 〈, or 〉 but couldn't
get Coq to accept ▷ or ▹.
I suspect the problem is that Coq doesn't actually understand utf-8 and so
some utf-8 sequences happen to only use octets considered as
symbol-constituents whereas others are less lucky.  This assumes that Coq
does not consider all octets 128-255 as symbol-constituents (maybe because
it assumes those octets are latin-1 chars or invalid control chars (for
128-159)).
        Stefan
