- From: Assia Mahboubi <Assia.Mahboubi AT sophia.inria.fr>
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] unification and modules
- Date: Tue, 21 Jun 2005 21:02:10 +0200
Hello,
I have some difficulties in understanding how unification is performed on
the following example (sorry it is a bit long):
Here is a module type for the argument of the functors to be defined.
Module Type PARAM.
Parameter A:Se.
End PARAM.
Then the following functor:
Module M1(P:PARAM).
Record rec(A:Set):Type := mk_rec{f:Set}.
End M1.
will be used to define two (very similar) objects in two distinct modules.
Module M2(P:PARAM).
Import P.
Module PM1 := M1 P.
Import PM1.
Definition rec2 := mk_rec A A.
End M2.
Module M3(P:PARAM).
Import P.
Module PM1 := M1 P.
Import PM1.
Definition rec3 := mk_rec A A.
End M3.
I would have said that the types of rec2 and rec3 are unifiable,
so I try this:
Module test(P:PARAM).
Module testM1 := M1 P.
Module testM2 := M2 P.
Module testM3 := M3 P.
Import P.
Import testM1.
Import testM2.
Import testM3.
Definition t(n:nat):=
match n with
|O => rec3
|_ => rec2
end.
But this raises the following error message (using either v8 or CVS):
Error: Unable to unify the types found in the branches:
For "0" : "PM1.rec A"
For "S" : testM2.PM1.rec A"
Could somebody explain to me what happens?
Thanks a lot in advance...
Cheers
assia
This message was sent using IMP: http://horde.org/imp/
- [Coq-Club] unification and modules, Assia Mahboubi
- Re: [Coq-Club] unification and modules, Hugo Herbelin
