- From: Pierre Casteran <pierre.casteran AT labri.fr>
- To: xiang sen <xiangsen AT ustc.edu>
- Cc: anoun AT labri.fr, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] How about this tactic definition!
- Date: Thu, 23 Jun 2005 15:54:53 +0200
Selon xiang sen
<xiangsen AT ustc.edu>:
> Ah! Thanks a lot!
> But if I define splitex like this :
> Ltac splitex :=
> repeat match goal with
> | H : ex _ _ |- _ => inversion_clear H
> end.
If you type
About ex
You will see that ex's first argument "A" is implicit :
ex : forall A : Type, (A -> Prop) -> Prop
Argument A is implicit
Argument scopes are [type_scope _]
Expands to: Inductive Coq.Init.Logic.ex
So, in order to write your tactic splitex, you can either do the same as
Houda,
or something like :
Ltac splitex :=
| H : ex (A:= _) _ |- _ => inversion_clear H
end.
But the pattern with two plain positional arguments won't work.
Pierre
> Then
> (**** Example **)
> Require Omega.
> Lemma ex_try:forall m,(exists n:nat, n<m)->(exists n:nat,n+2<m)->m>=3.
> intros.
> splitex.
> splitex doesn't work.
> Why ? :)
> Sen
> anoun AT labri.fr
> wrote:
> >Hi Sen,
> >Your tactic works if you use the type 'ex' instead of its notation (exists
> _:_,
> >Ltac splitex :=
> > | H : ex _ |- _ => inversion_clear H
> > end.
> >(*very simple example*)
> >Require Omega.
> >intros.
> >splitex.
> >omega.
> >Qed.
> >Houda
> >>Hi , everyone :
> >>I used below to define a tactic :
> >>Ltac splitex :=
> >>| H : exists _:_, _ |- _ => inversion_clear H
> >>end.
> >>But it does not work. Coqtop reports :
> >>Syntax error: [constr:ident] expected after 'exists' (in
> >>[constr:binder_constr]
> >>All the best!
> >>Sen
> >>Bug reports: http://coq.inria.fr/bin/coq-bugs
> >>Archives: http://pauillac.inria.fr/pipermail/coq-club
> >> http://pauillac.inria.fr/bin/wilma/coq-club
> >>Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
> >This message was sent using IMP, the Internet Messaging Program.
Pierre Casteran
http://www.labri.fr/Perso/~casteran/
(+33) 540006931
- [Coq-Club] How about this tactic definition!, xiang sen
- Re: [Coq-Club] How about this tactic definition!,
anoun
xiang sen
- Re: [Coq-Club] How about this tactic definition!, Pierre Casteran
xiang sen
anoun
