coq-club - Re: [Coq-Club] How to match several hypo. in Ltac
chronological Thread
  • To: Pierre Casteran <pierre.casteran AT labri.fr>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] How to match several hypo. in Ltac
  • Date: Mon, 27 Jun 2005 15:01:48 +0800
Pierre Casteran wrote:
Selon xiang sen
<xiangsen AT ustc.edu>:
Thanks.
But what I want is matching several hypothesis,
because I need multi hypoth in the tac.
You mean, it's necessary to use "match .. match ..." instead of
"match goal with [h1: t1; h2 :t2;..|-C]"?
I find in P.203 of Coq art that "The keywords "match goal with "
indicate that patterns are applied to match the goal. The patterns
have the form [h1 : t1; h2 : t2; ..|- C]=>tac". Why what I do does not work?
OK,
But it seems to work !
Ltac bimatch T :=
match goal with | [h1:T, h2:T |- _] => clear h1 end.
Goal nat -> nat -> nat -> nat -> bool.
intros.
bimatch nat.
bimatch nat.
bimatch nat.
Restart.
intros; repeat bimatch nat.
The reason why I proposed another solution was in your first mail:
Ltac indom :=
match goal with
| [h1 : heap; h2 : heap] |- ] => clear h1
end.
(** doesn't work **)
In fact, it is syntactically incorrect.
Pierre
If bimatch doesn't fit your requisites, please tell us what the tactic must
do (i.e. to which kind of goals it must be applied, and which subgoals
it must generate).
Thanks a lot!
By the way, the pattern described in Page 203 of Coq art should be corrected, shouldn't it?
Best regards
Sen
