- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Post.Doc and Assist. Prof. position Radboud University Nijmegen
- Date: Tue, 05 Jul 2005 00:23:46 +0200
Radboud University Nijmegen - Institute for Computing and Information Science
One 3 year post-doc position and
One 3 year assistant professorship in the NWO-sponsored project
ARPA: Advancing the Real use of Proof Assistants
We are seeking one researcher at the level of Postdoc and one Assistant
Professor (UD) for a period of three years, starting from September 1 2005
Candidates should have
- Good knowledge of at least one and preferably more of the following
fields: Type Theory, Proof Assistants, Formalizing Mathematics,
Logic and Automated Reasoning.
- For a postdoc position: a finished PhD in computer science,
mathematics or logic
- For an Associate Professor (UD) position: additional experience in
education.
Description of the project
Proof Assistants help the user in developing a theory (stating definitions and lemmas), model ling systems (describing constructions, giving definitions) and verifying properties about these systems (giving proofs). So, Proof Assistants are very generic tools to support Formal Methods. Their genericity makes them less efficient than tools that are especially geared towards a specific formal method. On the other hand they have a very precise semantics, which makes a the certainty of a result that is verified by a Proof Assistant very high. This is especially the case for PAs that are able to produce "proof objects" that can be checked independently. In the future, the very high level of certainty will prevail. In this project we want to advance the use of PAs in several ways: (1) by developing a "mathematical input mode" for PAs, making theme more easy to use, (2) integration of different PAs, allowing the exchange of results, (3) developing a certified library for real number computation in Coq, (4) verifying hybrid systems in Coq, using the library of (3) to model and verify system properties. The quality of (3) will be judged by its applicability to (4), but (2) and (3) will also be judged by its applicability to the formalisation of the proof of Kepler's conjecture.
For detailed information see the full project proposal. It will be sent
to you on request (email to
herman AT cs.ru.nl).
The positions
The project leader is Dr. J.H. Geuvers. The research will be performed within the research group "Foundations" of the ICIS institute of the Radboud University Nijmegen, in collaboration with Prof.dr. H.P. Barendregt and partly in collaboration with Prof.dr. F. Vaandrager from the "Informatics for Technical Applications" research group.
The research of the post-doc will be on topics (1) and (2) above. The Assistant Professor will have a 50% research - 50% education task; the research of the Assistant Professor will be on topic (3) above.
(Research on topic (4) will only start in September 2006, when a second post doc research position will become available.)
Applications
The full project proposal will be sent to you on request
(herman AT cs.ru.nl).
Further enquiries can be made with the project leader.
You are invited to send your application by email to the project leader. Deadline for applications is July 14, 2005. In case you learn of this job opportunity later than that date you may send an email to enquire whether it still makes sense to apply.
Your application should consist of:
- a curriculum vitae (containing information regarding your
academic degrees, title of your PhD-thesis, publications)
- the names and addresses of two referees
Please indicate clearly in which of the two positions you are interested.
- [Coq-Club] Post.Doc and Assist. Prof. position Radboud University Nijmegen, Herman Geuvers
