coq-club - Re: [Coq-Club] Fix_F vs Acc_iter
chronological Thread
  • From: David Pichardie <david.pichardie AT irisa.fr>
  • To: roconnor AT theorem.ca
  • Cc: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Fix_F vs Acc_iter
  • Date: Thu, 28 Jul 2005 09:39:44 +0200
Hi Russell,
In my opinion Fix_F is only provided to propose a fixpoint equation lemma Fix_eq
http://coq.inria.fr/library/Coq.Init.Wf.html#Fix_eq ;.
Hence you can define your function with a weak type (nat -> nat for example) with the Fix_F
constructor and in a second time make proof on it.
With Acc_iter, you have to use a strong type which contains the specification (or a part of it)
of your function and prove its correctness at the same time you program it. It's a beautiful experience but
it gives sometimes a headache...
The problem with Fix_F is that it requires an extra hypothesis on the functionnal you use (F_ext).
See the chapter about general recursion in the Coq'Art for more details.
Hope this helps,
David.
Le 27 juil. 05, à 18:34,
 a écrit :
On Wed, 27 Jul 2005
 wrote:
What's the difference between Fix_F and Acc_iter?
The follow up question is then ``What is the difference between Fix and
well_founded_induction?''; other than the fact that Fix has a bunch of
nice lemmas about it, while well_founded_induction does not.
Russell O'Connor                                      <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
          http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
David Pichardie
http://www.irisa.fr/lande/pichardie/index.en.html
