- From: Hugo Herbelin <herbelin AT pauillac.inria.fr>
- To: hywang AT pobox.com (Hao-yang Wang)
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Writing ad-hoc Tactics in Coq?
- Date: Sat, 6 Aug 2005 01:11:54 +0200 (MET DST)
Hi,
> Back in coq v6, there is a chapter in the reference manual to tell you
> how to write coq tactics in ocaml (Part III User extensions, Chapter 10
> Writing ad-hoc Tactics in Coq), but I cannot find similar information
> from the latest reference manual for coq v8.
> Is such information available for coq v8?
It has to be done but unfortunately it is not.
> If not, can I still use the material from the v6 reference manual as
> a starting point?
Coq data structures and Ocaml entry points in the source of Coq have
really changed a lot since V6. You'll have to study the source
(typically the files kernel/term.ml, pretyping/termops.ml,
tactics/tactics.ml, tactics/tacticals.ml, tactics/extratactics.ml4,
... see also the files in dev).
You may also find help on this list.
Hugo Herbelin
- [Coq-Club] Writing ad-hoc Tactics in Coq?, Hao-yang Wang
- Re: [Coq-Club] Writing ad-hoc Tactics in Coq?, Hugo Herbelin
