coq-club - Re: [Coq-Club] Anomaly: Cannot take the successor of a non variable universes
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Anomaly: Cannot take the successor of a non variable universes
  • Date: Fri, 2 Sep 2005 10:50:42 +0200
On Thu, Sep 01, 2005 at 03:56:06PM +0200, Lionel Elie Mamane wrote:
> m   : nat
> v   : vec Prop (S m)
> IHm : vec Prop (m) -> Prop
> Prop
> I'd like to destruct v into vcons a v', in order to do:
>  exact (a -> (IHm v')).
> But then I get this anomaly:
>> destruct v.
> Anomaly: Cannot take the successor of a non variable universes:
I noticed (helped by Pierre Courtieu) that the problem is more
subtle. Here is a minimal script that reproduces it:
Set Implicit Arguments.
Inductive vec : Type -> nat -> Type :=
  | vnil  : forall A:Type, vec A 0
  | vcons : forall A:Type, forall n:nat, A -> vec A n -> vec A (S n).
Definition vmap : forall A B:Type, forall f:A->B, forall n:nat, vec A n ->
vec B n.
induction n.
intros; exact (vnil B).
intros va.
inversion va.
rewrite H in X0; rewrite H1 in X0; rewrite H in X.
rename A into a; rename X0 into va'.
clear H H1.
exact (vcons (f X) (IHn va')).
Defined.
Lemma f : forall m   : nat,
  forall v   : vec Prop (S m),
  forall IHm : vec Prop (m) -> Prop, Prop.
intros.
destruct v.
Note that:
1) Removing vmap: No anomaly
2) Adding "Reset vmap." before "Lemma f": Still anomaly!
3) If I define vect, vmap, then do "Reset Initial." then re-define
   vec, but not vmap, I still get the anomaly.
So it seems that the definition of vmap irremediably "clobbers" the
state of Coq in a way that is _not_ cancelled by Reset! Naively, I'd
call this a "Reset" bug... Defining something and then resetting it is
not equivalent to not defining it, which it is supposed to be, isn't
it?
Lionel
