coq-club - Re: [Coq-Club] Inductive Types allowed eliminations
chronological Thread
  • To: Enrico Tassi <gareuselesinge AT virgilio.it>
  • Cc: Coq-Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Inductive Types allowed eliminations
  • Date: Fri, 9 Sep 2005 14:38:28 +0200
 > Table of allowed eliminations:
 >             |   Inductive Type   |    Elimination to         |
 >             | Sort | "Smallness" | Prop | SetI | SetP | Type |
 >             | Prop     unit      | yes    yes    yes    yes  |
 >             | Prop     small     | yes    [yes]  no2    no12 |
 >             | Prop               | yes    no2    no2    no12 |
 >             | SetI     small     | yes    yes    --     no1  |
 >             | SetI               | yes    yes    --     no1  |
 >             | SetP     small     | yes    --     yes    yes  |
 >             | SetP     (* inductive type is rejected *)      |
 >             | Type               | yes    yes    yes    yes  |
A few remarks :
no2 should not only be related to extraction, but also to the possibility
to contradict proof irrelevance (if you define Bool in Prop, you will
be able to prove true<>false)
Prop small SetI should also be marked no2
SetI small Type should be yes
Christine Paulin
 > Legenda:
 >   1 : due to paradoxes a la Hurkens
 >   2 : due to code extraction
 >   [yes] : Current version of Coq rejects this, but a comment in the source
 >           code seems to allow this elimination. (See indtypes.ml line 479)
 >   SetP : Predicative Set
 >   SetI : Impredicative Set
 >   very-small : Constructor arguments are in Prop only
 >   small : Constructor arguments are not in Type
 >   unit : Non (mutually) recursive /\ only one constructor /\ very-small
 > Thanks in advance
 > Enrico Tassi
 > Bug reports: http://coq.inria.fr/bin/coq-bugs
 > Archives: http://pauillac.inria.fr/pipermail/coq-club
 >           http://pauillac.inria.fr/bin/wilma/coq-club
 > Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
  Christine Paulin-Mohring             mailto :
Christine.Paulin AT lri.fr
  LRI, UMR 8623 CNRS, Bat 490, Université Paris Sud,   91405 ORSAY Cedex
  tel : (+33) (0)1 69 15 66 35         fax : (+33) (0)1 69 15 65 86
