- From: Pierre Casteran <pierre.casteran AT labri.fr>
- To: roconnor AT theorem.ca
- Cc: Adam Chlipala <adamc AT cs.berkeley.edu>, Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Dependently-typed binary operators
- Date: Tue, 13 Sep 2005 09:30:50 +0200
Hi,
In the 2004 version of the tutorial on [co]-inductive types (available through coq's page : http://coq.inria.fr
"Additional documentation" ) there is a case study on dependent elimination (p 49-54) , using a double
recursion combinator.
The attached file contains an example very similar to the statement given in the first mail of this thread.
Hope this helps,
Pierre
wrote:
On Tue, 13 Sep 2005
wrote:
Think about what the two goals will be after the destruct. Write out what
they are. Then you will realize it will be neccesary to
unfold band32.
Actually now that I think about it, it is not clear from the resulting
goals that it is neccesary to unfold band32. Furthermore you probably
don't want to do destruct; destruct will generalize away the 32 and
consider both constructors.
You don't want to do this. You know your vector is of lenght 32, so you
know there is only one possible constructor. What you want instead is
dependent inverison. The solution to your 2nd order woes is seems to be
to generalize anything related to your term.
In this case you will need to do
generalize e2
clear e2
unfold band32
dependent inverion e1
Of course the next thing you will want to do is
dependent inversion e2.
But how you are going to do that is beyond my skills. I'd be tempted to
do the whole proof via (vector (bool*bool) 32). Perhaps others know
better solutions.
Welcome to the nightmare that is programming with dependent types. ;-)
Require Import Bvector.
Definition xorb (b1 b2:bool) :=
match b1, b2 with
| false, true => true
| true, false => true
| _ , _ => false
end.
Definition Vtail_total
(A : Set) (n : nat) (v : vector A n) : vector A (pred n):=
match v in (vector _ n0) return (vector A (pred n0)) with
| Vnil => Vnil A
| Vcons _ n0 v0 => v0
end.
Definition Vtail' (A:Set)(n:nat)(v:vector A n) : vector A (pred n).
intros A n v; case v.
simpl.
exact (Vnil A).
simpl.
auto.
Defined.
Implicit Arguments Vcons [A n].
Implicit Arguments Vnil [A].
Implicit Arguments Vhead [A n].
Implicit Arguments Vtail [A n].
Definition Vid : forall (A : Set)(n:nat), vector A n -> vector A n.
Proof.
destruct n; intro v.
exact Vnil.
exact (Vcons (Vhead v) (Vtail v)).
Defined.
Eval simpl in (fun (A:Set)(v:vector A 0) => (Vid _ _ v)).
Eval simpl in (fun (A:Set)(v:vector A 0) => v).
Lemma Vid_eq : forall (n:nat) (A:Set)(v:vector A n), v=(Vid _ n v).
Proof.
destruct v.
reflexivity.
reflexivity.
Defined.
Theorem zero_nil : forall A (v:vector A 0), v = Vnil.
Proof.
intros.
change (Vnil (A:=A)) with (Vid _ 0 v).
apply Vid_eq.
Defined.
Theorem decomp :
forall (A : Set) (n : nat) (v : vector A (S n)),
v = Vcons (Vhead v) (Vtail v).
Proof.
intros.
change (Vcons (Vhead v) (Vtail v)) with (Vid _ (S n) v).
apply Vid_eq.
Defined.
Definition vector_double_rect :
forall (A:Set) (P: forall (n:nat),(vector A n)->(vector A n) -> Type),
P 0 Vnil Vnil ->
(forall n (v1 v2 : vector A n) a b, P n v1 v2 ->
P (S n) (Vcons a v1) (Vcons b v2)) ->
forall n (v1 v2 : vector A n), P n v1 v2.
induction n.
intros; rewrite (zero_nil _ v1); rewrite (zero_nil _ v2).
auto.
intros v1 v2; rewrite (decomp _ _ v1);rewrite (decomp _ _ v2).
apply X0; auto.
Defined.
Require Import Bool.
Definition bitwise_or n v1 v2 : vector bool n :=
vector_double_rect bool (fun n v1 v2 => vector bool n)
Vnil
(fun n v1 v2 a b r => Vcons (orb a b) r) n v1 v2.
Fixpoint vector_nth (A:Set)(n:nat)(p:nat)(v:vector A p){struct v}
: option A :=
match n,v with
_ , Vnil => None
| 0 , Vcons b _ _ => Some b
| S n', Vcons _ p' v' => vector_nth A n' p' v'
end.
Implicit Arguments vector_nth [A p].
Lemma nth_bitwise : forall (n:nat) (v1 v2: vector bool n) i a b,
vector_nth i v1 = Some a ->
vector_nth i v2 = Some b ->
vector_nth i (bitwise_or _ v1 v2) = Some (orb a b).
Proof.
intros n v1 v2; pattern n,v1,v2.
apply vector_double_rect.
simpl.
destruct i; discriminate 1.
destruct i; simpl;auto.
injection 1; injection 2;intros; subst a; subst b; auto.
Qed.
Definition bodd (v:vector bool 32) :=
vector_nth 0 v = Some true.
Definition beven (v:vector bool 32) :=
vector_nth 0 v = Some false.
Goal forall (v1 v2: vector bool 32),
bodd v1 /\ bodd v2 -> bodd (bitwise_or _ v1 v2).
intros v1 v2 (B1,B2).
red.
generalize (nth_bitwise _ v1 v2 0).
intro H.
generalize (H _ _ B1 B2).
simpl (true||true).
auto.
Qed.
- [Coq-Club] Dependently-typed binary operators, Adam Chlipala
- Re: [Coq-Club] Dependently-typed binary operators,
roconnor
roconnor
- Re: [Coq-Club] Dependently-typed binary operators, Pierre Casteran
Conor McBride
roconnor
- Re: [Coq-Club] Dependently-typed binary operators, Conor McBride
roconnor
roconnor
- Re: [Coq-Club] Dependently-typed binary operators, Frederic Blanqui
roconnor
