- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Optimizing outputs of program extraction?
- Date: Thu, 15 Sep 2005 16:22:33 -0700
I am interested in using Coq's extraction facilities to speed the checking of proofs by reflection. However, the very literal translation that I get with commands like "Recursive Extraction" has some opportunities for optimizations that lead to asymptotic improvements, are easy to implement on typed OCaml ASTs, but that the OCaml compiler is not smart enough to perform.
For example, I would like to replace all uses of Coq's nat with uses of OCaml's int, relying on dynamic checks to determine when the representation is not precise enough and abort the execution. I can think of some simple type-directed syntactic rewrite rules that would accomplish this, and there are a number of other basic but very worthwhile optimizations of this kind.
Can anyone point me to an existing tool that performs such optimizations?
Also, the Coq'Art book mentions extraction optimizations that lead to the removal of any 'sig0' types, the use of 'bool' instead of 'sumbool', etc., in the extracted program. These don't seem to be applied for "Recursive Extraction" in my installation of Coq 8, even after I run "Set Extraction Optimize.". Is there some way I can enable them?
Thanks!
- [Coq-Club] Optimizing outputs of program extraction?, Adam Chlipala
- Re: [Coq-Club] Optimizing outputs of program extraction?, Lionel Elie Mamane
Pierre Letouzey
Stefan Karrmann
- Re: [Coq-Club] Optimizing outputs of program extraction?, Adam Chlipala
Stefan Karrmann
