- From: Virgile Prevosto <virgile.prevosto AT m4x.org>
- To: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Admitted theorems within sections
- Date: Thu, 13 Oct 2005 13:50:36 +0200
Hello,
Le jeu 13 oct 2005 13:01:32 CEST, Pierre Casteran
<pierre.casteran AT labri.fr>
a ecrit:
> When developping some large proof segmented in sections, I met the
> following scheme.
> Section S.
> Hypothesis H : P.
> Lemma difficult_lemma : Q.
> Admitted. (* But I presume that H is used in this proof *)
> Theorem corollary : R.
> Proof.
> ... apply difficult_lemma.
> Qed.
> End S.
> Since there is no proof term for the lemma, if the corollary doesn't
> apply directly H, the discharging mechanism makes the type of
> corollary being R (and not P -> R). That means that all the
> development after S's closing will be inconsistent when I (at least)
> prove the lemma.
We had more or less the same issue in Focal. A possible solution would
be to rely on an auxiliary (admitted) lemma, and define difficult_lemma
with an explicit reference to H. It is not very elegant, but it works:
Parameter P Q:Prop.
Section S.
Hypothesis H : P.
Lemma difficult_lemma_aux : Q.
Admitted.
Definition difficult_lemma : Q :=
let _ := H in
difficult_lemma_aux.
Theorem corollary : Q.
Qed.
End S.
Check difficult_lemma.
(* difficult_lemma : P -> Q *)
Check corollary.
(* corollary : P -> Q *)
E tutto per oggi, a la prossima volta
Virgile
- [Coq-Club] Admitted theorems within sections, Pierre Casteran
- Re: [Coq-Club] Admitted theorems within sections, Virgile Prevosto
Pierre Casteran
- [Coq-Club] session residentielle, Marie-Renee FLEURY-DONNADIEU
Pierre Casteran
