- From: Hugo Herbelin <herbelin AT pauillac.inria.fr>
- To: Assia.Mahboubi AT sophia.inria.fr (Assia Mahboubi)
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Notations
- Date: Mon, 21 Nov 2005 10:54:41 +0100 (MET)
Hi,
> I have been a bit disturbed by the following behaviour of Notation :
> a name used as a Notation does not become reserved even for the time
> the current section being opened.
Notations of the form
Notation id := ...
define a qualified identifier (they correspond to "Syntactic
Definition" of the pre-V8 syntax). As such, they can be referred to
using a long name as shown in the following session.
Coq < Notation a0 := (X0 myelem).
Coq < Locate a0.
Notation Top.a0
Coq < Check Top.a0.
a0
: A
so that the notation a0 should'nt clash in any context with the
variable a0.
However, while checking your example, I found a bug. For instance, in
the following modified example
Set Implicit Arguments.
Record elem(X:Set) : Set := mk_elem{X0 : X}.
Variables (A:Set) (myelem : elem A).
Inductive eq : A -> A -> Prop :=
|refl : forall a:A, eq a a.
Lemma test : forall a:A, eq a a0.
Proof.
intro a0.
you should see
1 subgoal
a0 : A
eq a0 Top.a0
what you won't if you don't use the today update of Coq 8.0 (cvs
tag V8-0-bugfix)...
Regards,
Hugo Herbelin
- [Coq-Club] Notations, Assia Mahboubi
- Re: [Coq-Club] Notations, Hugo Herbelin
