coq-club - Re: [Coq-Club] Help proving
chronological Thread
  • From: Pierre Casteran <pierre.casteran AT labri.fr>
  • To: Li Long <liwisster AT gmail.com>
  • Cc: Lionel Elie Mamane <lionel AT mamane.lu>, COQ-CLUB <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Help proving
  • Date: Wed, 23 Nov 2005 13:56:08 +0100
Li Long wrote:
Thanks all for helping me!
Pierre's example does help me a lot to recognise the problem inside
my formalization of the form
forall ( T : Set )( A : Prop ), ( forall x : T, A ) -> A.
It seems there are times the domain that quantified variables refer to
needs to be non-empty, or it is a implicit rule in natural deduction that
the domain is always non-empty when there are quantified variables
refer to. I have not met comments of the latter in literatures about logic,
and I would not like to formalize logic lemmas in the style of the latter,
because I think it reduce the power of many logic lemmas.But if the
former is the case, how can I tell whether a non-empty premise should be
added when formalizing a logic lemma, possibly a complicated one?
You can prove your results within a section containing some non-emptiness
hypothesis. If this hypothesis is not used in some proof, it will not appear
after closing the section.
In the following example, I add some non-emptiness hypothesis through a witness u.
(Notice that I could have declared H : exists u:U, u=u  as well).
The proof of L depends on this hypothesis, but not L'.
If you check L' after sections's closing you will see that this hypothesis doesn't
appear.
Hope this helps,
Pierre
Section Non_empty.
Variable U : Set.
Variable u : U. (* U's inhabited *)
Variable A : Prop.
Lemma L : (forall (x:U), A) -> A.
Proof.
 intro H;apply H;exact u.
Qed.
Lemma L' : forall (x:U),x = x.
auto.
Qed.
End Non_empty.
Check L.
L
    : forall U : Set, U -> forall A : Prop, (U -> A) -> A
Check L'.
L'
    : forall (U : Set) (x : U), x = x
Section Non_empty2.
Variable U : Set.
Hypothesis inh : exists u:U, True.
Variable A : Prop.
Lemma L2 : (forall (x:U), A) -> A.
Proof.
 case inh.
 auto.
Qed.
End Non_empty2.
Cheers,
Long
