coq-club - Re: [Coq-Club] Exploiting variable binding of Coq for encoding lambda-calculus
chronological Thread
  • To: nouvid-coq AT yahoo.fr
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Exploiting variable binding of Coq for encoding lambda-calculus
  • Date: Wed, 7 Dec 2005 08:43:50 +0100
On 07/dic/05, at 06:30, Fabrice Lemercier wrote:
Hello
I want to encode lambda calculus is Coq in such a way that it uses the variable binding mechanism of Coq. But the following definition is rejected by Coq because of the non strictly positive occurrence of Term in (Term -> Term) -> Term.
Inductive Term : Set :=
  abs : (Term -> Term) -> Term
| app : Term -> Term -> Term.
Is there a workaround?
Fabrice
If you do not need induction nor recursion, you can go for an "open" definition (a la LF):
Parameter Term : Set.
Parameter abs : (Term -> Term) -> Term.
Parameter app : Term -> Term -> Term.
Otherwise, if you want to exploit the inductive types of Coq, you have to use a separate type for variables, e.g. as follows:
Parameter Var:Set.
  var : Var -> Term
|  abs : (Var -> Term) -> Term
Coercion var : Var >-> Term.
In this way, alpha-conversion comes for free, but substitution is not delegated to the metalanguage and must be encoded explicitly.
This technique is called "weak HOAS" (or second order abstract syntax); also, the development of metatheoretic results about systems encoded in this way is facilitated by the so-called "theory of contexts", that is some basic principles about Var and terms of type (Var->Term) which can be added to the signature as Axioms.
See the following papers for full details:
Marino Miculan, Developing (Meta)Theory of lambda-calculus in the Theory of Contexts.
In Proceedings of the Workshop on MEchanized Reasoning about Languages with variable bINding (MERLIN 2001). ENTCS 58.1, Elsevier, 2001.
Furio Honsell, Marino Miculan, Ivan Scagnetto, An axiomatic approach to metareasoning on systems in higher-order abstract syntax.
In Proceedings of ICALP'01, Number 2076 in Lecture Notes in Computer Science, pages 963-978, 2001.
Furio Honsell, Marino Miculan, Ivan Scagnetto, Translating Specifications from Nominal Logic to CIC with the Theory of Contexts.
In R. Pollack, editor, Proceedings of MERLIN'05. ACM DL, 2005.
-marino
  Marino Miculan - Department of Mathematics and Computer Science
University of Udine  - via delle Scienze 206, 33100 Udine - Italy
vox: +39-043255-8486 - fax: +39-043255-8499 - mob: +39-3292606452
mail:miculan at dimi uniud it  http://www.dimi.uniud.it/~miculan/
