[Coq-Club]Re: Difficulties explaining to Coq how to refine a dependent elimination
chronological Thread
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club]Re: Difficulties explaining to Coq how to refine a dependent elimination
- Date: Thu, 29 Dec 2005 15:47:47 -0500
- Cancel-lock: sha1:8BVIMgtUSLYSjPTH3ibFfTnYQso=
> I have the following definition:
> Inductive ULeq (k:Set) : list k -> list k -> Set :=
> | ULeq_refl : forall l, ULeq l l
> | ULeq_skip : forall l1 l2 x, ULeq l1 l2 -> ULeq (x::l1) (x::l2).
> And I'd like to prove:
> Definition test k (l1:list k) l2 l3 x :
> ULeq l1 l2 -> ULeq (x::l2) l3) -> ULeq (x::l1) l3.
> I expected the following to work (modulo incomplete pattern matching, of
> course):
> (PE1: ULeq l1 l2) (PE2 : ULeq (x::l2) l3)
> : ULeq (x::l1) l3 :=
> match PE2 in ULeq l2' l3 return ULeq (x::l1) l3 with
> | ULeq_refl l => ULeq_skip x PE1
> end.
For those who, like me, can't stand the non-declarativeness of Coq tactics,
the answer looks like the code below:
(match PE2 in ULeq l2' l3 return (x::l2 = l2') -> ULeq (x::l1) l3 with
| ULeq_refl l => fun P:(x::l2=l) =>
match P in _ = l return ULeq (x::l1) l with
refl_equal => ULeq_skip x PE1
end) refl_equal.
I.e. yu have to manually construct a proof of equality, refine that proof
via the `match', then match on the proof to finally do the substitution
you wanted.
The `inversion' tactic does that for you if you use tactics.
Stefan
- [Coq-Club] Difficulties explaining to Coq how to refine a dependent elimination, Stefan Monnier
- Re: [Coq-Club] Difficulties explaining to Coq how to refine a dependent elimination, roconnor
- [Coq-Club]Re: Difficulties explaining to Coq how to refine a dependent elimination, Stefan Monnier
