coq-club - Re: [Coq-Club]Proposal for Finite Types in the Standard Library
chronological Thread
  • To: roconnor AT theorem.ca
  • Cc: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club]Proposal for Finite Types in the Standard Library
  • Date: Tue, 31 Jan 2006 10:17:15 +0100
Dear Russell,
Coq's inductive types have a new functionality which allows one to define a wider range of
parametric inductive types than before. This should allow the definition of Fin n as a parametric inductive type
with n as a parameter.
(NB: This functionality was used by Marco Maggesi in his contribution defining the Lambda calculus using this
new kind of inductive type--Carlos) .
One encounters a little problem due to the fact that (pred 0) = 0. Here is a quick work-around to give a definition.
We aren't sure if this could simplify the treatment of finite types, if there is a better work-around, etc.; however,
in reply to your message, we feel that it would be good to ask whether it is possible to give a more streamlined treatment
of finite types using this new kind of parametrized inductive type.
Here is a proposition for some code, not sure it compiles though:-(? (In any case it would require a very recent edition of Coq).
Definition is_zero (n:nat) : bool :=
match n with 0 => true | S m => false end.
Definition non_zero (n:nat) : bool :=
match n with 0 => false | S m => true end.
Inductive boolset : bool -> Set :=
boolset : boolset true.
(* recall pred n = n-1, the only problem is pred 0 = 0. That is why we define
FinConditional first. *)
Inductive FinConditional (n : nat) : bool -> Set :=
 | fin_prev : FinConditional (pred n) (non_zero n) -> Fin n true
 | fin_zero : boolset (is_zero n) -> FinConditional n true.
Definition Fin n := FinConditional n true.
Briefly, FinConditional n false is supposed to always be empty. Thus fin_prev
doesn't introduce anything new if n=0.
For n=0 the constructer is fin_zero (which in turn doesn't introduce anything if n>0).
---Marco Maggesi and Carlos Simpson
