- To: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]heyting arithmetic
- Date: Wed, 08 Feb 2006 08:42:18 -0800
Michael O'Connor wrote:
I'm interested in verifying things which can be proven in Heyting Arithmetic, i.e. intuitionistic Peano Arithmetic, so there is no higher-order induction. Would it be possible to do something like define a type HA_Prop such that if P : HA_Prop and t : P then t is guaranteed to be a proof just using first-order induction. Thanks very much,
You can always axiomatize a sufficiently restrictive proof system inside of Coq (probably with inductive types), and instead ask for t : MyProofsOf P, where MyProofsOf is an indexed inductive type of proofs that you define. I'd be surprised if there's a way to restrict the use of higher-order induction without doing something like this suggestion.
- [Coq-Club]heyting arithmetic, Michael O'Connor
- Re: [Coq-Club]heyting arithmetic, Adam Chlipala
- Re: [Coq-Club]heyting arithmetic, Benjamin Werner
