- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club]specification and Type
- Date: Thu, 02 Mar 2006 10:32:55 +0100
Hi,
In plane geometry, where points are elements of a Set (Parameter Point : Set.)
and lines are defined as property on points (Definition Line := Point -> Prop.),
I would express one of the incidence axiom saying that I can construct three
points, say A, B and C, such that for every line, there exists an algorithm for
finding the point among these three points, that does not belong to the line.
So I try :
Axiom I4 : {A:Point &
{B:Point &
{C:Point &
(forall D : Line, {~(D A)}+{~(D B)}+{ ~(D C)})
but Coq refuses since (forall D : Line, {~(D A)}+{~(D B)}+{ ~(D C)}) has
type Type when Set is expected.
I would know if
- I have written a bad formule, and a correct one will be accepted by Coq,
- this is not possible for a fundamental reason,
- or it is not possible with the current version of Coq.
Thanks
Jean Duprat
- [Coq-Club]specification and Type, Jean.Duprat
- Re: [Coq-Club]specification and Type, Lionel Elie Mamane
- <Possible follow-ups>
Yves Bertot
- Re: [Coq-Club]specification and Type, Julien Narboux
