- From: Pierre Casteran <pierre.casteran AT labri.fr>
- To: Ricardo Sousa <c0107040 AT alunos.dcc.fc.up.pt>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]Wrong answer Exercise 6.29 of the book
- Date: Tue, 28 Mar 2006 16:23:57 +0200
Selon Ricardo Sousa
<c0107040 AT alunos.dcc.fc.up.pt>:
Hi,
I tried again this solution with coqV8 (pl3) and found no problem.
Could you send me a script of the session?
Pierre
> Hi.
> In the exercise 6.29, where i can only use certain rules to prove
> "Theorem plus_n_O : forall n, n+0 =n.", there is a problem in the given
> solution
> (http://www.labri.fr/perso/casteran/CoqArt/structinduct/SRC/plus_n_O.v)
> on the application step.
> Open Scope nat_scope.
> Proof.
> intro n; elim n; simpl.
> reflexivity.
> intros n0 e.
> apply eq_ind with (P:= fun n => S(n0 + 0) = S n) (x:= n0 + 0).
> reflexivity.
> assumption.
> Qed.
> I can't find why this doesn't work.
> I also don't understand in which step of the unification this error
> corresponds. Is in the app rule? Or is in other?
> Toplevel input, characters 260-324
> > apply eq_ind with (P:= fun n1 => S (n0 + 0) = S n1)(x:= (n0 +0)).
> Error: Impossible to unify "S (n0 + 0) = S ?29" with "S n0 = S n0 + 0"
> Thank you in advance,
> Ricardo Sousa
Pierre Casteran
http://www.labri.fr/Perso/~casteran/
(+33) 540006931
This message was sent using IMP, the Internet Messaging Program.
- [Coq-Club]Wrong answer Exercise 6.29 of the book, Ricardo Sousa
- Re: [Coq-Club]Wrong answer Exercise 6.29 of the book, Pierre Casteran
- Re: [Coq-Club]Wrong answer Exercise 6.29 of the book, Ricardo Sousa
