- To: Satrajit Roy <admin AT satrajit.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]Inheritance in Coq?
- Date: Mon, 3 Apr 2006 12:48:00 +0200
Hello,
If you mean "some recursive term of type xKind" etc. instead of
"some recursive term using xKind", yes.
This is not inheritance but dependent types.
You need a function such as
Definition kind_of k :=
match k with
| x => xKind
| y => yKind
| z => zKind
end.
Then the body of your fixpoint is something like this:
match k return kind_of k with
| x => something of type xKind
| y => something of type yKind
| z => something of type zKind
end.
Hope this helps,
JF
Satrajit Roy a ecrit :
> I'm new to Coq. How can I define something like the following in Coq:
> Inductive kind:Set:= | x | y | z.
> Inductive xKind:kind:=|x'|x''|..|x''''.
> Inductive yKind:kind:=|y'|y''|..|y''''.
> Inductive zKind:kind:=|z'|z''|..|z''''.
> FixPoint funcKind (k:kind) (...) .. {struct k} : kind := match k with
> | x => some recursive term using xKind
> | y => some recursive term using yKind
> | z => some recursive term using zKind
> end.
> I know the above is syntactically wrong. But I hope I got my intention
> across.
> Is the above even possible?
> Thanks in anticipation.
Jean-François Monin Univ. Joseph Fourier, GRENOBLE
VERIMAG - Centre Equation http://www-verimag.imag.fr/~monin/
2 avenue de Vignate tel (+33 | 0) 4 56 52 03 72
F-38610 GIERES fax (+33 | 0) 4 56 52 03 44
- [Coq-Club]Inheritance in Coq?, Satrajit Roy
- Re: [Coq-Club]Inheritance in Coq?, jean-francois . monin
