- From: Pierre Casteran <pierre.casteran AT labri.fr>
- To: Pierre Casteran <pierre.casteran AT labri.fr>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club]Using coqdoc
- Date: Wed, 03 May 2006 11:20:49 +0200
I tried another way:
putting the option --glob-from htmllinks for coqdoc in the makefile
then doing make html
as a result, each subdirectory has is proper index.html and html file for ecah module, but
none links within or between html files.
Is coqdoc truely compatible with multi-directories developments with a single makefile ?
Pierre
Pierre Casteran wrote:
Hi.
Which is the good option for coqdoc in case of a multi-directory development ?
I have a development splitted in various subdirectories D1 D2 D3.
I call coq_makefile D1/*.v D2/*.v D3/*.v -I D1 -I D2 -I D3
and I manage to have : COQC=$(COQBIN)coqc -dump-glob htmllinks
and a target
doc: $(VFILES)
$(COQDOC) --glob-from htmllinks \
$(VFILES)
The problem is that all html files are put in the current directory with names like
D1.M1.html, D2.M2.html, though the a- links in html files have the (correct)
form ".../D1/M1.html"
Is there something to change in the call to coq_makefile and/or the options to coqc and coqdoc ?
Thanks,
Pierre
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club]Using coqdoc, Pierre Casteran
- Re: [Coq-Club]Using coqdoc, Pierre Casteran
Lionel Elie Mamane
- Re: [Coq-Club]Using coqdoc, Frederic Blanqui
Lionel Elie Mamane
